Exhaust Manifold FO-4?
Tomatoboy
Um...are the exhaust/intake manifold remove and reinstall instructions omitted from the FO-
4 manual, or am I just having a bad reading day?
I apologize if this has come up before, I had trouble finding the torque specs and mine
needs replacement.
i looked that one up the other day. 27 foot/pounds. don't ask me where i found it, i just remember it was a pain to find.
The nuts are brass, 7/16-20 x 5/8, NAPA part number STN104X, 27 lbs of torque. Fastenal has them for about $1.50 each; part number 75133. OEM studs are 1-5/8 long 7/16-14. NAPA doesn?t stock the 5/8?s length, but part number RFD 86644, 1 ? inch, works as does part number 86632, 2 inches. These studs are ?Handi-Pack? items. (I?ve used these longer studs on my 50 & 51 N?s, but you should make sure they do not bottom out in the block on your N as they are longer than OEM). If you don?t get them at NAPA, make sure that the stud has an egg-shaped center between the different threads. Use washers under the nuts.
If you're really lucky, you can get the nuts off w/o removing a stud or damaging it. And, if you buy a ticket, you could win the lottery. Drain the block & plan on at least one stud getting replaced!
There are two distinctly different recommendations on tightening the studs in the block. Because the stud goes into the water jacket & is constantly undergoing extreme heat & cooling cycles, some folks like to double-nut them & tighten them down at 37 lbs of torque. Others say that it?s a stud & should only be finger tight w/ a good dose of thread sealer or high temp silicone on them.
I?ve replaced the studs on 3 of my 4 N?s w/ no leaks; I finger tighten the studs then take a ? turn on them w/ vice grips.
75 Tips
Good news! All four nuts came off with almost no effort. Oddly, three were wider than normal, but the ID was the same. Made it hard to get a socket in the small space the nuts hide in, if I?m honest. Not sure if those were ?heavy duty? or what, but I replaced them with OEM nuts and put everything back together. No more gasket leaks for me.
