F-12 Crankcase Oil Level
wbcelec
Is there any way to check the oil level when you do not have petcocks or dipstick? Could you measure from the oil fill neck down with a flexable rod?
Assuming there is no way to return petcocks to working order and assuming you don't have a dipstick(W-12 type pan) I would pull the drain plug draining the engine oil completly. Find a service manual and know exactly how much oil the crankcase is supposed to hold and measure that amount out and put it in. In the mean time I'd get a working oil level check system (working pan) on that old bird.
I suppose you could install a sight glass such as instrumentation or some pipe fitting applications use though if you have gone to the trouble of removing the pan and are going to attempt such a thing you could just as easily solder in the proper pet cocks which as I recall are still available from Rice Equipment.
It is mysterious to me why yours would not have them. Did it come with a dipstick which has since become lost? Or is it not somehow a combination of parts which now includes neither a block with a dipstick or a pan with the petcocks?
I don"t think you would have any luck getting a tube through there. I would get the right pan on it if it doesn"t have petcocks. The kero models have 3 petcocks and the gas tractors have 2.
