F-12 FINALLY on full rubber!
I know some of you guys followed my rebuild on this tractor over the past few years. Or maybe more like the past 5 years! About a week ago I decided to forget buying 40" tires and see if I could locate a set of 36" round spokes and maybe a decent set of used 36" tires. Didn't take but a few days and had my hands on both!!!
I've already logged around 40 miles on the tractor and I'm beyond happy! I need to get it on a dyno and see what kind of HP I'm actually getting. It'll hold 15 MPH even on some good hills. Starts out in high 3rd easily.
Wish I had been able to find those for my 14. I have over $1500 in tires and rims in mine, and that's just the rears.
(quoted from post at 12:22:57 08/08/17) seth what ever happened with the wide front axle you had???
I still have it. My future plan is to build another tractor using the original rear steel and maybe adapt steel to the wide front.
(quoted from post at 10:24:28 08/08/17)
Put my 12 on 36" spokes too. Used 13.9-36 tires and a set of spokes for $250. The tires ended up being the same height as the steel when the lugs are sunk in the ground.
(quoted from post at 05:52:47 08/09/17)
That's looks great! I wondered how much bigger tire would would ok on the 6" wide rim. I'm in the market for those same weights now. I missed out on getting a set for about $280 a while back.
Big Red, I never realized how many F-12 were retro fitted with updates over the years. Lots of F-12's got long brake handle and raised steering post. Some got new engine's with F-14 valve cover breather. The thing I find is you have to go back to the serial # to check for sure. The give away on most F-12 that look like F-14 is the 2 bolt radiator air breather seems that stayed on most.
(quoted from post at 18:46:04 08/09/17) oldiron29, AHA! Thanks for enlightening me. All best regards, kelly
IH had a field upgrade for the 12 to make it a 14, including a run of serial numbers. Many however were updated much later with 14 parts. There are many F14's with the 2 bolt air cleaner as that change came late in their production run so be careful with that one. One thing I start with is that the 14 has a universal joint close to the steering box, while the conversions usually have a rubber disc set up further away from the gear case.
(quoted from post at 12:15:20 08/09/17) I love steel,they never go flat
And they tear up the yard, slide off of trailers when loading and unloading, and would ruin the floor in my shop. I like to drive mine around instead of just look at them.
