F-20 Governor Update
C Fitz
Adjusted the linkage on the connecting rod fork and got the engine to respond perfect while accelerating to full throttle, but the throttle lever still
wants to creep down when throttled to a idle? Guess I'm half way there. Any suggestions? Thanks
I assumed you are talking about the levers on the steering column. If so, there is a spring on the rod holding the tube against the steering column.
The lever on steering post is the spark advance lever. The one on left side of fuel tank is throttle.
My F-20 doesn't have that throttle on the left side, although I wished it did like my F-30's, my throttle is the another lever by spark advance. And yes, I'll check that spring out today on steering column , thanks.
