F12 Waukesha
I recently got an old F12 Farmall that my grandpa was working on restoring before he passed away a few years ago. He did a lot of work on it, and I want to finish the restoration. It has the flathead Waukesha engine, but the jets had broken off the original carb so he got it running with a Model A Ford carb.
His brother gave him a couple of Zenith carbs that should be correct for the engine but one is missing a jet and the jets look plugged on the other. Does anyone know of anybody that rebuilds the carbs?
Also, if anyone has any leads on governor linkage and a linkage cover it would be appreciated. I could make my own linkage but it would be nice o have as close to original as possible.
Thanks James, The carbs I have are from Waukesha engines, did the IHC engines use the same one? I figured it probably changed when the engine manufacturer changed.
I see a lot of places with parts for the IHC overhead valve engines but not a lot of flathead waukesha.
