F18D control
Status
Not open for further replies.
Lee-HT
Under the seat on the right side is a slot in the sheet metal. There is a M6 stud coming from underneath. This stud is on a bent bar about a half inch wide that connects to a small rotating plate with a M3 shaft going down into an upper part of the rear housing. When I move the stud toward the front it rotates the M3 shaft and slows the engine down about 400 RPM.
The Murray Owners manual shows it as a 4WD but it doesn't engage the 4WD. That lever is low left of the Tran housing.
What is this?
Lee
Never mind. I looked so more.
The rotating shaft is a control that sends fluid to another box under it that has a HYD hose coming out the back that is looped back into the same box. This can be used for HYD attachment like maybe a tiller?
Thanks anyway.
Status
