Thanks,(quoted from post at 00:04:15 10/31/21) Congrats on your purchase. Send me an email and I will
send you a link to a manual for it. As far as the questions,
we are not mind readers.
Thank you all!(quoted from post at 11:15:35 10/31/21) well those engines have babbit poured brgs. there is inspection holes in the lower block. many times the babbit gets worn and no one keeps up
on stuff. there is shims to remove as the brg. wears. and yes they have an oil pump. have only low oil pressure maybe 15 lbs. oiling the top
is only to oil the valve train.
Thanks, we are in that process now. Pulled card yesterday its a fresh rebuild but cleaning anyway. Found a spot in the fuel line that looks like a hole was JB welded. Also sediment bowl had no screen of any kind, just the bowl. Had some crap in it, so its in pieces up to the tank. Making a new fuel line today, and will put card back on.(quoted from post at 08:47:04 11/01/21) Starting easy and dying after a few minutes under load is probably a fuel restriction. Pull the drain plug on the carb, put a receptacle under it, and let the gas run for a few minutes -- the flow should fill a pint jar pretty quickly. If it's slow, work through the fuel system back towards the tank until you find the restriction. There is a screen in the carburetor inlet fitting that a lot of people don't know is there.
Yes(quoted from post at 12:06:52 11/01/21) U bought from Ottawa kansas
Outside of Lane KS(quoted from post at 14:48:22 11/01/21) Where are you from u
You live down the road from Croan with all the Farmalls.(quoted from post at 07:57:47 11/02/21) I live east and south of lane
I have been by there, are you the dad or son. I have spoke to the son at Croans before. John and I are pretty good friends. Although, I am not one of the regulars there.(quoted from post at 19:52:26 11/02/21) Yep
This tractor is a 1936.(quoted from post at 17:49:44 10/31/21) Tractor is a 1937.The cast wheels are from a '39.The round spoke is what cam standard in '37.
