Fab work, post brackets
We plan to build a lawn tractor shed. I am going to make concrete posts for in ground with wood posts anchored above for the structure. Galvanized brackets are $6 ea so decided to make them out of scrap metal. Took about 1 hour. It was raining so not much else to do outside
Are you going to weld galvanized pins to go into the concrete ?, And how will you treat the welds ? I admire your creativity, BUT, the cut edges will need something to reduce rust. Just sayin' .
I have some galvanized 1/2? hook bolts. The center hole is 1/2?. The brackets will be inside the siding so, not worried about edge rust.
