Yes when I start it up it will not run it dies out.(quoted from post at 12:48:32 04/05/19) Is there something not working right on tractor, or just want general info?
Get a owner's manual will answer a lot of maintenance Q's. Tractordata.com also can be helpful.
k I will try that.(quoted from post at 15:14:48 04/06/19) Use a flashlight and look in the gas tank to see if something might be blocking the intake hole. I had that happen once and solved the problem with one of
those flexible grabber thingies. Ellis
(quoted from post at 07:28:26 04/07/19) I have tried to adjust the carb but one of the adjustment screws is stuck.
Ok I will check the gas tank then .Thanks For your help Tom(quoted from post at 14:55:05 04/07/19) If it starts and runs for 20 to 30 seconds, then quits, you can leave that screw where it is. The issue is likely to be the fuel supply as mentioned in my other
post. If it will idle all day, but not speed up without dying, it is likely the load screw mentioned in my earlier post. Or just some fuel getting to the carb.
not enough to provide higher speed. Jim
