What size fan belt does my to-30 tractor use? It was already converted to a 12volt system when I purchased it. The alternator pully looked like it came off of a lawnmower deck and was worn out. When I bought a new correct pulley the belt is too wide. My belt looks to be 3/4 wide and does not fit my new pully. Any help will be appreciated. Thanks.
Go to an auto parts store and get one that fits the pully. When installed the belt should have ~ 1/2" to 3/4" (2cm) of deflection.
I can't imagine your tractor using anything but a standard 1/2 inch Vee belt. To properly measure, I would get some nylon or jute rope about 1/2 inch thick, route it over the pulleys as if it were a belt, then mark where the end of the rope meets the remainder. This should get you within 1/2 inch or so of the proper size, you should have and inch or so of leeway to work with from the way the alternator pivots to tension the belt.
AFAIK the TO 30 belt should be 41.5 inches long and 5/8 inches wide. The pulley MF # 1750509M1 is for the 5/8 wide belt. Being as you have an alternator I can't be sure the belt is correct. The pulley will fit a your generator and Delco 10SI and some others but you did not say what alternator you had so am guessing.
No, No, No. Somebody that did not know what they were doing put an alternator set up for one of them wimpy little car belts. The pulley on your crank and on your water pump are for the correct 5/8 inch belt just like came from the factory. The generator that was pulled off had the same size pulley and could have been transfered to a Delco alternator. That is water under the bridge now. If you have a real auto parts store, they can fit you up with a 5/8 pulley. If you have a Delco, you can order the one Duner said. Otherwise, any alternator/starter rebuild shop can fix you right up.
How do I know? The "reputable" tractor dealer I bought my tractor from pulled the same stunt. I know a good starter re-builder luckily. The stock belt will fit just fine then.
