fan drive shaft
I am redoing an A serial # 545065 with a fan drive shaft that is chewed up where the generator pulley goes on. I have a parts tractor in the woods A serial # 596724. I know the shaft housing is different but I'm hoping the shaft is the same. Does anybody know before I stand in the woods in the snow and tear this thing apart?
The parts book shows it to be two different shafts. In fact there is even another part number shaft in between the serial numbers you mention. From a physical standpoint, I don't know what the difference is.
Your tractor #545065 falls in a gray area concerning serial number tags. Does you tractor have the steel tag, or aluminum, if it's not too much trouble?
Thanks
Tim
ser# 545065 uses A1176R, the later A uses A3663R.I'd say, Stay In where it's warm.it's different. In the parts book they look different in the area with the ventilater pump on the later one. I have shortened and rewelded them for an early AR.
