This message is a reply to an archived post by cliffyboy on January 03, 2016 at 18:11:21.
The original subject was "Fan shroud or not".
One day I heard a small noise when mowing. Thought nothing of it as it was the blade slightly touching the shroud in one small spot. After an hour it got louder, then suddenly the fan shredded the shroud. I
figured it was due to a water pump with bad bearings, YET there was no grinding sound coming from the water pump. I replaced the water pump, yet there was just a little wiggle in the shaft of the old pump. I
also bought a new shroud, and could get the screws to fit one side but not the other without having to drill pilot holes to force it to fit. I haven"t fully mounted the shroud, but testing it, the darn blades
are hitting it too!
Someone suggested the main pin at the front axle that holds the axle to the body could be worn out causing wiggling in the front axle making everything out of alignment including the fan/shroud combination.
Ever hear of this?
are hitting it too!
Ever hear of this?
