I want to thank everyone who responded to my "starter problem" for my Farmall 100. I tried most of the suggestions to no avail. I ended up pulling the starter and in so doing found the spring retaining bolts were loose. I then pulled the armature/core out of it's casing and found the brushes and the armature core were filthy with a gooy goopy , gummy substance. I don't know how it was able to make enough contact to even turn it over once! I cleaned up the armature and emory clothed the works and put it back together. (Boy, what a pain that was! Trying to keep the brushes wide enough to slide the core down in was a challenge. My wife, who was "HELPING" only argued with me three times dring the 1 1/2 hours it took to 'get that starter back together.. I must admit it was her idea that worked. We used grape ties to hold back the brushes while we slid in the core and then cut the ties and pulled them out) Anyway, I put the starter back in and the tractor started right up
So I want to thank you all for the info/help/suggestions that you supplied!!!!!! tired 8n
