Farmall 100 Steering
PaulH
I have a problem with the steering on my 100 The screw gear or the sector gear must be worn as have replaced tie rod ends and spindle bushings.Has any one replaced these parts and are parts available from Case IH and is the screw gear part of the steering shaft or is it removeable?
Paul in Ontario
Paul: Unless there is end movement in the steering shaft, the steering worm is fine. Very likely your problem is on the vertical shaft both inside and outside the steering box.
Inside the box, the half gear is keyed to the shaft via woodruff key. Outside the box the steering control arm is keyed to the same shaft via another woodruff key. If worn those two keys can create close to 1-1/2 turns free travel on the steering wheel. Those keys are the most common problem.
Where in Ontario, I'm near Strathroy.
Thanks Hugh for the info will be pulling apart shortly. I live near Ailsa Craig 232 4679.
Paul in Ontario
Paul: Well if one lives near Alsa Craig, he also lives near Strathroy. I think we've met, once at Jack Elliott's.
On two of my tractors, not only were the woodruff keys bad, but the keyways in the shaft were damaged. I used over size keys and ground them to fit. Actually the shaft keyway for the half gear was so bad, I welded a key in the shaft and ground it to a press fit with a hydraulic press. That was my Super A and it was 16 years ago and it's still tight as new. I did not weld the key in shaft on my 130, and it didn't stay as tight. Good but not as good as SA. 130 to has 15 years on it. The steering control arm is a bit easier as there is taper at that point.
