Farmall 140 Leaking Radiator
Aries68
I have a 1974 Farmall 140 and was removing some dirt out of one of the little slots on the front of the radiator about a couple inches from the top center and it started leaking radiator fluid out of that slot until it all drained out. I'm sure how it happened and not sure what to do. Any help would be appreciated.
I put some JB weld on a leak on my W30 radiator 30 years ago and its still holding. That is not a pressurized radiator but for a small spot it may not make a difference.
(quoted from post at 15:21:14 05/26/22) I put some JB weld on a leak on my W30 radiator 30 years ago and its still holding. That is not a pressurized radiator but for a small spot it may not make a difference.
Thanks for the suggestions. Apparently, I punctured something while using a small screwdriver to pry out some dirt but didn't think I could have done it that easily but it all ran out and down the front.
Also, if anyone knows a link to a video or description of how to actually remove the radiator from a Farmall 140, please share. I've never done it.
Several options...
Poke around the leak, locate the problem exactly. Scrape and clean the area carefully, the tubes are thin
and fragile. If you know how to solder, or know someone who does, it possibly can be soldered, especially if
it was punctured. If it just rotted through and started leaking the odds are slim for a good repair.
Or clean it up and try some JB weld. Same odds of success.
Find a radiator shop. The only ones left are heavy equipment shops, up to the individual if they will even
look at it. They may try to fix it or do a recore. A recore is the best option, but expensive. You;ll
probably have to do some groveling to get them to take the job. Need to assure them you are serious and not
price shopping!
Replace it with a China aftermarket. Cheap, maybe fit, maybe last, maybe not...
When I redid my A, I cleaned out crud in one spot on the radiator only to have a very nice stream come out when I was done. Ended up picking out some epoxy instead of crud. I removed the radiator and cleaned the spot real well, then reapplied some JB Weld. That was 10 years ago. Mine is a thermosiphon system with a 0 psi cap.
(quoted from post at 04:37:39 05/27/22) Also, if anyone knows a link to a video or description of how to actually remove the radiator from a Farmall 140, please share. I've never done it.
Its been close to 20 years since I had mine off its is a simple job.
