Farmall 140 Problems/Hyraulics
ncfarmer16
My farmall 140 has some major hyraulic problems(so i think). The front culivator hyraulics won"t go up or down. The lever will only move 1/16 of an inch if that. The back hyraulics works just fine. I already disconneted the lever and just tried to move the linkage, no luck. Do yall think it is in the hyraulic block too or what? Has anybody tore these down before, what should i look for? Also what does a GOOD useable hyraulic block is worth? Any info/help on these things? Thanks in advance
Mine gave me problems. Are you losing hydraulic oil and gaining motor oil? One time I removed the screen and cleaned it.It is on the left side of the hydraulic block. If you are low on hydraulic oil then you are probaly upon motor oil. The price of a rebuilt pump is ridiculus.
I took mine off and split the pump. There are 2 o rings in there and they are prone to go bad.
Get new gaskets though and don't try Permatex.
rebuilding the touch control is not that bad,,, its just big and heavy,,,the diagram in the parts book makes it much EZ'er to go buy,,, bite the bullet and git a CNH gasket and seal kit and a new pressure relief spring an tear into it,,, plan on a little less than $200 in parts and oil
