Farmall 140 radiator bracket
csangster
I have a 140 that has been in an accident in the past. My question is this, is the radiator bracket between the engine and the radiator supposed to have a dogleg bend in it or is it supposed to be a straight bracket?
Thanks,
Chris
It should have a bend in it. With out a picture I cant tell if yours is right or not. You can tell when you put the sheet metal on if the bend is right. If its bent to far the sheet metal will overlap to much.
