Farmall 140
John69
I'm restoring a Farmall 140, and the brakes are stuck, to where neither one of the pedals will push down. Does anyone have any idea how to unstick them? What part do I take off to get to the brake bands? Never done none of this before.
I would think it's not the bands that are sticking as much as the pedals are rusted to the shaft.
After reading your post this is just my thoughts but you didn't explain if the pedals were sticking or not. You just said the brakes.
Yes, the pedals are stuck in the up position, to where I can't push down on the brakes. I guess I should of been more clear.
Start soaking the pivots where the pedals pivot on the main shaft with PB Blaster , Kroil or any of the good penetrants you have available. Do this a couple times a day for however long it takes. Each time you soak them try moving them up and down. they will eventually break loose. Once you get them loose, oil them up good. If you really want to get perticular, pull the pedals off and polish the shafe and clean the pedal bushings and coat them with water resistant lithium grease. Chances are the bands are ok.
Really not a complicated job.
