Farmall 200 clutch installation
RayP(MI)
Son is reassembling my 200 after a major engine overhaul. New clutch plate is not centered on the hub. One side protrudes probably half an inch further than other. Which way does it install? Any torque specs for flywheel to crank? any torque specs for clutch assembly? Shop manual is conspicuously short on clutch information.
Not sure what you're question is, you need a pilot shaft to center the disc to the pilot bearing, I've used a universal alignment tool or the right size broom stick with the end cut down on a bench grinder to fit the pilot brg. If you're asking which way the disc goes the side with the springs goes inside the pressure plate unless you're working on an old Chevy Nova from a couple years in the 60s. They're backwards. Never noticed that disc doesn't look like it has springs in the disc hub but if it did they would be like in the last picture.
My new disk has no spring assembly, just the disk, hub, and two friction disks, plus assorted rivets.
