Made better progress than expected. Flywheel cleaned, remounted, pilot bearing installed, rear main seal in, throw out bearing installed and clutch mounted. Question before closing her up: I was surprised by the inward travel of the pressure plate fingers when the clutch housing was tightened to flywheel. This is a complete assembly replacement with pilot tool. Long side of disk hub facing out.
For clutch housing removal, the manual calls for wood wedges to presumably suspend pressure plate pressure against the disk and bolts for removal. The wedges in the illustration look very small. Id need 1/2 wedges to further depress the fingers.
Are there any measurements for clutch fingers to top of clutch housing, or top of disk hub to top of fingers?
