Farmall 200 Engine Block
I found the front casting, but now I am in need of a engine block.
I took mine to Rex in Cambridge IA and after he looked at it suggested that I try to find a good used one.
Anybody have any thoughts
or have one that they might consider parting with.
You did give them the measurement of your sleeve at the bottom where the o-ring goes after all the yrs to have the correct
block for that measurement because you never know till a sleeve is pulled and measured there
The problem was between two of the water ports and the cyliner bore
Both sides of the number three hole about .020 space between
sleve and block wall
