Farmall 230 Questions
BearFrye
[size=9:70689d4195][/size][/size:70689d4195]
I have an old farmall 230 and I can t find where you put the hydraulic fluid or the trani fluid, dose anyone know?
This post was edited by BearFrye on 03/24/2023 at 06:48 pm.
Hello bear welcome to YT! Sorry, not real experienced
with the Farmalls smaller than an H. In the cast box
under the back of the gas tank there should be a plug
with probably a square headed plug, usually sets at an
angle. In the link is the manufacturers online parts
catalog. The cast box is part 50, you can see the
reservoir under the top lid. The part list heading says it
is for a 200 but it is the same thing.
If you view this on a PC you will see that from that
page you can navigate to all the parts sections for your
tractor. On a phone that site is a little tricky.
CNHI Farmall 230 online parts catalog.
(quoted from post at 01:16:46 03/25/23)In the diagram tube 37 sticks down to pick up the oil in the transmission.
Not in the transmission. The hydraulics use a dedicated reservoir in the torque tube.
Before you put the fluid in be a good idea to inspection to clean or replace the screen-filter and gasket . Will be worth the time . Just a
suggestion , to make it work better . Purged out air with movement of each control lever ten times .
Can see it in hydraulic section for 230 on messicks site
