Still having problems with the left brake locking up on the left side. The distance from the mounting surface of the drum to the wear surface is 2.22 inches and the thickness of the pads is 1.00 inches when put together. Is that within the tolerances?
The pads have plenty of material left. I took the expander plates apart and they seem fine. No excessive build up or anything. I cleaned them and the balls up but still no dice. I don't want to get too crazy cleaning them up and take too much material away and cause more problems. As I am typing this I got to thinking if maybe the springs on the expander plates are a little weak. Would that cause this issue? Thanks in advance.
