Farmall 300 missing
bpanning92
I picked up a farmall 300 last summer and it ran great up until a month ago and started missing. It will run on #2 and #3 but when I pull plug wires on 1 and 4 there’s no change. I have spark to 1 and 4 if I hold the plug about 1/8” from the block but no spark when grounded directly. I put new plugs, cap, wires on it. Checked compression and put good gas in it. It has a 12v battery positive ground but still has a generator and 6v coil (I’m assuming since it ohms at 1.4). There is a 12v sylnoid on the starter. Looks like a newer voltage regulator but Im not sure If it’s 6v or 12v. Is there a way to tell if it has been converted or if the guy I bought it from just threw a 12v battery in it? Kind of chasing my tail here since the manuals I have may not have the conversion info in it.
change your firing order to clockwise, 1342. from the sounds of things you have it counterclockwise. and thats what will happen run on 2 and 3.
The title of your post reminded me of a write-up by a fellow pilot in the military: "Engine missing". Mechanic's sign off: "Engine found in place".
yes, was thinking that also , how can it run on 2 cyl's if the tractor is missing ? thought it was stolen at first.
(quoted from post at 12:32:00 11/30/20) The title of your post reminded me of a write-up by a fellow pilot in the military: "Engine missing". Mechanic's sign off: "Engine found in place".
I was going to ask if he had called the police.
If it started missing while it was running, and not because you changed wires, then it is possibly a bad distributor shaft bushing. With the cap off of the distributor, try to move the rotor shaft up and down, away from the engine and toward it. If you can see/feel it move at all, the bushing is bad. Rebuilt distributor is available right here on YTmag. Setting the point gap (with the engine turned so the points are open as far as possible) to .020" might help temporarily. Jim
Either you missed mention of them or they are your problem, the points. Did you check them and set the gap? Needs to be 0.020 of an inch gap when stoped on the high lobe. Excess distributor bushing wear can also cause firing variations between cylinders.
Sense it ran all summer, I would assume it must be charging unless you had to charge it between uses.
Have you put a volt meter on it to see what the revved up voltage is across the battery?
That will tell if it is charging. The battery may be run down to 6v and still have enough to start and run with the 6v coil.
What do you want to do with the electrical? Keep it 6v or finish converting it to 12v?
If you are looking for dependability and economic fix, put a Delco 10SI one wire alternator on it, and add a 1 1/2 ohm resistor to the coil.
If you want 6v originality you'll need a battery and start working on the generator and regulator, which will be an ongoing task.
If the points have been running on 12v without a resistor, they are probably cooked. Take a look and check the gap, check the condition of the distributor shaft bushings and the advance mechanism. Be sure the cap is good, not carbon tracked between cylinders on the underside.
my bet is the same also! like to see the correct fix on this. we never get the actual order of stuff done . i am sure 2 wires are crossed. as he says has good spark when unplugged. i know its not points or bushings the way he describes it.
This guy was missing for a couple days. I didn’t hear the rest of the story, but I bet it was crossed wires.
In my experience, points don't know & don't care if they are fed by a 6V or a 12V source, they are more concerned about the amps the coil & or condenser is supplying them. It's the coil that cares how many volts feed it. The points sets that are used on a right angled Delco distributor used as an after market replacement for a letter series Farmall tractor's magnetos is the same set as used in later Chevy's with a 12V electrical system.
OK, let's get a couple of things straight here.
Points affect ALL cylinders - not just one or two. Same with condensers. Same with distributor bushings. So, now let us get back to basics.
An engine needs THREE things to run:
1) Fuel/air mixture.
2) properly timed spark.
3) Compression.
If you have those three things, the engine will run. Now, as to what is missing. You say that it runs on 2 and 3 but not 1 and 4. That tells you that it is something that is NOT common to the whole engine. That rules out points, condenser, coil, and distributor bushings. It also rules out timing.
You already did say that you have spark at 1 and 4. Check under the cap first to see if there is any moisture or carbon tracking. Then it is time to check for vacuum leaks. With the engine running, spray a bit of carburetor cleaner or starting fluid around the intake manifold. Any sudden change in engine RPM while you are spraying will indicate a vacuum leak.
Next, check your compression. Usually, just listening to the sound as the starter turns the engine will tell you if there is a compression problem. Better to use a gauge, but in a pinch, just using the starter will point out an obvious difference in compression. You should hear a steady loading and unloading as each cylinder passes over TDC on the compression stroke.
There are a number of things that can cause a cylinder to misfire. Spark plug, plug wire, carbon track in the distributor cap, Valves adjusted too tight, burned valves, vacuum leaks, crossed wires, head gasket, and the list goes on. But, those are the major things that will cover most misfiring problems. You need to look for something that is specific to each cylinder that is not firing. Not something that is common to all cylinders.
Jim, it does pay to check the point gap, just to rule it out.
I've seen many times the rub block running dry and the points were barely breaking, and due to runout and wear on the distributor shaft they would open for some of the lobes, and then when it turned to the other side they would remain closed.
Jal, yes the points and condenser are the same, regardless of the volts.
But BOTH the coil and points are load sensitive.
Running a 6v coil on 12v without adding a 1.5 ohm resistor will overheat both the coil and the points. The amp load will be too high on the points. It will make a hot spark, but just won't do it for very long!
Points in general will affect ALL cylinders. It would be a nearly impossible coincidence for points to cause one or two out of four cylinders to misfire. Why take the long way around to troubleshoot a misfire? And, why waste the man's time pointing him in the wrong direction?
I have been working with engines since I was old enough to pull the rope on my dad's old reel lawn mower. I've never seen points cause one or two cylinders to misfire. Normally all or nothing.
