farmall 350
sniperwolf
what would cause a behaln powersteering not to work on a farmall 350 rc ive replaced all the o rings on the whole tractor and put new hoses on but when i move one of the hydraulic levers powersteering works fine could the powersteering valve not be centered with the pressure hose outlet?
parts breakdown
The issue is likely a stuck demand valve in the Safety regulator valve (closest to the steering shaft) that valve, if stuck) will not allow the system to pressurize. Part 10 in the diagram. It also has a screen attached. Jim
Upvote 0
parts breakdown
Hello sniperwolf, welcome to YT! In the link Jim gave you click the “next arrow” I believe that this shows you the proper diagram for the Safety Regulator Valve on a power steering equipped tractor. The valve shown horizontal on the lower left (22) controls flow to the PS. It could also be sticking and causing this problem.
Upvote 0
anything i should watch out for when removeing it can i remove one snap ring or should i remove the whole valve dont really wanna take gas tank off just for that
Upvote 0
