Farmall 400
Bought first 400. Need to add/change hydraulic fluid before spring. Where would I drain it and where do I find the fill hole? Does this fluid also run the transmission or are there other ports for draining and filling the trans. Getting ready for spring planting and cultivating. Thanks David
The hydraulic and the rear end are seperate. Here are pictures of the drain plug and filter cover for the hydraulics. When I put the new T/A in it a couple of years ago, I put Hy-Tran in the rear end. Just use universal Hydraulic fluid in the hydraulics, or can use hytran. Chris
