oldfarmall
Hello all-
Thought I would give an update for my Farmall 450 cylinder head and coolant leak issue. I took the head to my engine machine shop. They pressure tested the cylinder head and magnafluxed for cracks. Found one crack in combustion chamber #3. Also pressure tested head to 40 PSI, but it did not leak under the pressure test, even with the crack. The crack was not next to the exhaust valve, it was off to the side more. They mentioned that this head had hardened valve seat installed, and the exhaust valves looked great. Even though the head did not leak under the pressure test, he said it still possibly could during heating and cooling cycles once bolted back on tractor, so I should try to get the crack welded before reinstalling. By looking at the head when I brought it in, the tech thought maybe the head gasket was to blame for coolant getting into #3 and #4 cylinders from the black colored staining around each combustion chamber.
Upon further investigation, this engine had an IHC head gasket made by Victor Reinz that I removed. It had Victor #1698, IHC #369957R2 stamped on it. I am thinking this is the wrong head gasket for a C-281 gasoline engine with cylinder head 362174R1, the pistons are the 374306R1 domed fire craters also. If I am looking at the parts books correctly, it should use head gasket 48957DE, or Victor 3149, correct? Any thoughts? Thanks!
-Jesse
-Jesse
