Hi everyone,
I have a farmall 460 with a 263 (560) engine in it with fire crater pistons. Its totally rebuilt and runs well except a little skip which I think could be solved with electronic ignition because the distributor is a bit worn and I think the points open with a different gap each time. Yes I know I could rebuild it but I could also just change it to electronic ignition and solve the problem with an upgrade. So my question is which kit have you all used to convert to electronic ignition?
Also I've been told I could use a later model carburetor to eliminate the hesitating or hiccup the tractor has when you pull back on the throttle quickly. I guess some of the later tractors had accelerator pumps? Anyone have suggestions on which carburetor I should upgrade to?
Any advice is appreciated!
