Farmall 504 hydraulic issues with loader
Timryan0735
I have a Farmall 504 with loader and I can not figure out the hydraulic problems does some one have pictures of the hydraulic lines and where they run to I have the loader hooked up to the front ports if u have both lines hooked up the loader will not go up if u have just the one hooked up it will go up and down just fine but I can t lift more the 500 pounds with it my number is +17018093300 be the best way to get ahold of me
Don t honestly thing so have pressure just no clue what s going on it honestly acting like the lines are crossed but there not
Can you provide a little more information? Such as, is the tractor and loader new to you or have you had it a while? Did you remove the loader recently? Did it work fine before? What loader is it? Have you tested the pressure of the hydraulics on the tractor?
Honestly it sounds like you have the hoses crossed up. I know you said that they aren't but are you SURE? Sometimes we look at things so many times that we just glance and assume that it's right. Done that a few times with spark plug wires myself.
Many loaders from around the time of the 504 were pressure up gravity down. So there would only be one hose for the boom cylinders. The second hose would go with a third hose and together they would control the bucket tilt.
I only had the tractor for about 6 months I got it because the guy that had it was going to scrap it due to head gasket none of the hydraulic where hooked up when I got it s the cylinder on the loader have up and down and had lines running to it I check the lines and rechecked I also had another person check the lines they are not crossed
