Farmall 504 power steering
leeedwin9
I have a municipal IH 504 (painted yellow) that looks like a row crop model with a beefy wide front axle. It has power steering via a hydraulic cylinder that"s positioned near the front axle. Recently the power steering stopped working entirely. The rear end is full of hytran and the aux hydraulics still work well. Prior to the steering failure the tractor wanted to "wander" all over the road. Any ideas what is wrong?
Most 504's have a 2 section hydraulic pump- I think one section is for steering and 3 point, the other for auxilliary- but don't quote me. Several different setups, industrial might be different, your mileage may vary, some assembly required.
All of which is to say you just about have to get a book to sort it all out. Guess I'd suspect the pump, unless you can figure out where all that oil that used to steer your tractor is now going.
