Farmall 504 water pump
Daniel Vader
My fan is rattling against the fan shroud on the radiator. If I wiggle the fan back and forth it has obvious play in what I assume is the bearing. Is this a separate thing from the water pump? What do I have to replace to remedy this?? Thanks in advance.
you tell us if it connected to the water pump. most fans are connected some not. such as the 282 diesel. but anyhow get this looked into A.S.A.P. OR you will be replacing the rad also. regardless you have loose brgs there , so if its the pump yes replace it.
Yes. Fan is attached to pump.
