Farmall 560 Gas Clutch problems
TLW
I am having a problem with the clutch not fully disengauging when it is pushed in. It was working fine until I recently replaced the hydraulic pump then, with in an hour or so the clutch started acting up. I dodn"t know if it is simply a coincidence or maybe I hit something when replacing the pump. I know that this isn"t a hydraulic clutch but was hoping that there might be an adjustment that could be made or something I could look for. The tractor runs fine when I can get it into gear. Any suggestions?
I had a 560 and I remember it was a challenge to get the clutch and ta linkage coordinated. Did you remove the linkage to install pump? I bet you just don't have the linkage adjusted right. Someone more experianced than me will come on and walk you through it.
