I have a IH 560 I got a couple of years ago. It appears that it has not had the best of care but it has always started good until now. I checked a spark plug and it looks very poor. It is a Champion # D 21. Would you recommend that I replace it with the same plug or a different plug?
Also, I am going to change the hydraulic fluid. It is very milky and probably hasn't been changed for many years, if ever. Can I simply drain the oil and replace it or do I need to somehow clean all the old oil that doesn't drain out? I suppose it will run out easier if it is warmed up. It has a loader so there is oil in the lines that might not all drain down. I hate to put expensive oil in if I haven't adequately drained the old oil.
