Farmall 560 head
bhshot
I have a 1958 Farmall 560 that I pull with. It does ok but I know I need to rebuild the engine. It appears to have the stock 263 gasoline block and head. I have ruled out putting a bigger engine in it, and I know I will be limited as to what I can do to that engine. My questions is what cylinder head will work best with my engine? A lot of people talk about small or closed chamber heads. Port and polishing also. Slanted cylinder head? How about a cam? Governor work? Any help on this subject would be greatly appreciated. Thanks
Truck head,pull the sleeves and put over bore 301 piston in,rework the governor,use 301 combine carb thats a good start.
