farmall 584
Dave osborne
I have a 584 that has set for 4or 5 years removed fuel tank a cleaned well cleaned the lines changed fuel filters had injectors rebuilt
when I cranked the engine over its blowing some fuel up around the base of injectors I'm stuck now what?
Hi Dave, did you clean out the injector nozzle sleeve well and replace the "O" ring in the bottom of the sleeve? I believe CIH has a special tool for cleaning out the injector sleeve hole. According to I&T Shop Service manual the injector retaining bolt is to be tightend to torque of 18 ft-lbs.
JimB
