littlefarmer
I've got a Farmall 656 gas tractor that I use for farming. Pulling a tandem disk, and also hauling wagons of grain.
Acquired it about four years. Since the beginning, I've had a problem with it running lean. Always had to keep the choke out about 1/2 to get it to run right. It seems plenty of others have had the same problem with these tractors.
I tried everything--rebuilding the carburetor, replaced it twice with a pro-rebuilt one, new gaskets on the manifold, making sure there was no problem with the fuel delivery. New spark plugs, distributor cap, installed electronic ignition, double checked timing. Checked compression and valve clearance. Even got rid of the shut-off solenoid and replaced it with a needle-type main jet adjustment. Nothing helped.
So, awhile back I'm looking at the original IH parts book for this tractor. Checking out the carburetor section. I noticed for the main jet, it specifies a #52 drill bit size.
Purchased a set of small numbered drill bits. I check-out the jet size, on my existing carb, and it won't take anything larger than a #55. (With numbered drill bits like this, as the number gets lower the bit gets larger).
So I take a chance, and drill-out the jet the next size larger (#54). And hey! The tractor runs noticeably better!. I go down to a #53---runs smoother yet!
I've finally drilled it out to the #52 size, as specified in the parts manual. Now it runs perfect under load. No sputtering. No fiddling with the choke.
I check both the previous rebuilt carburetor I got, and also the original one that came with the tractor. The jets are at #55 size.
So I am wondering---why do the rebuilt carbs and rebuild kits currently sold, have a three-sizes smaller main jet, than what is specified by IH? Is it because the OEM jets are NLA? And the remanufacturers just stick in whatever will fit? Despite knowing that it won't run right?
Wanted to post this out here for any others who have been having this problem. I've seen more posts on this subject from other Farmall owners on the Internet, with the same problem. I'm hoping my fix will help them also.
PS---I've also found it's important to use genuine 91 octane gas in these tractors! (This is the octane level that IH specifies for these engines). DO NOT run standard 87 octane! It caused performance issues for me!
