I had to dig-in to the 5 speed transmission on my Farmall 656 to replace the 4th gear sliding gear. (It had a broken tooth).
I'm also replacing the main shaft pilot bearing, as a matter of course.
However, I am wondering if I need to replace the countershaft bearings, and also the main shaft rear bearing. They all seem to be in fine condition. Also the main shaft rear bearing is kinda expensive ($300), and removing it would mean checking the mesh with the differential and all that. Also--removing the countershaft is another major piece of work. The countershaft bearings also appear to be in good condition, and the 4th gear on the countershaft also seems to not have any excessive wear. If everything seems ok, do I need to mess with any of this other stuff.
Just asking for other's opinion on this. I use the tractor for farming---mainly light field work (spraying, disking).
