Farmall 666 hydraulics
Dr. Evil, Pete23, other IH gurus.
Wanting to run a round baler that requires 1800 psi hydraulics behind a 666. As we know the 666 is set at 1600 psi. Will it hurt anything to replace the 1600 psi relief valve with a 2000 psi valve? Will the rest of the system hold up. TIA.
Have you tried the baler yet? It just might work fine with what you already have.
I have a baler that is supposed to require higher hydraulic pressure than my two cylinder Deere will make, and it works fine. I hear the relief valve squeal when I am closing the baler, and I'm told that the baler has some sort of restrictor to prevent the door from closing to fast.
