I have a farmall 706 that I am trying to figure out the remote valves. I am understanding that this model should have a float position that the hydraulic lever should lock in. I had it hooked to a planter (jd 7000 conservation) for pre season maintenance.When I push down on the lever it will lock and the tractor buzzes like it is making full pressure and it is dead headed. I can push the lever further down and the planter will drop like it's on a true float but the lever will not lock in the float position. According to the planter manual I need to be locked in float for planting. So what do I need to start looking at on the tractor? Or do these models not lock into float?
