moore60.purdue
Good Morning,
My Dad?s has a Farmall 806 that I am having trouble getting the MCV pump to take a prime.
Where it all started:
The tractor stopped moving with a loud bang, coming from the speed transmission while cutting weeds. It still had power steering and brakes.
What has been done in chronological order that they were done:
We pulled all the transmission covers and couldn?t find anything wrong. We decided since the TA had been slipping in low or high (I can?t remember which) to replace it since we assumed it was the TA.
I split the tractor over the winter, and replaced the TA. The one way clutch came out with a handful of teeth and pieces. While I was in there I replaced the reverse driven gear because it was missing a couple teeth from the parking brake paw. I drilled a 1/2? hole in each side of the differential housing to the axle housing to let the oil circulate and maintain the proper level. (I read that it was an upgrade to the later models.) I also wiped down the inner housing and looked for any other metal shavings.
Put a new MCV pump in it (9 gpm used the same gear from the old one), new o-ring between the transmission housings around the metal ring on the brake side, new o-rings on the TA supply tubes, on the pump, new o-ring on the power steering supply line under the mcv, new check valve and spring, then put it all back together. We put a new detent bushings on it, and replaced a broken shifting mechanism with grooves in it that the detents ride in (I can?t remember what they are called and this one had a broken piece on the end). Then put new hy-tran fluid in it.
Had very little (and stiff) power steering and no brakes, but the TA would shift and it moved well after a quick adjustment of the shift linkages.
Pulled the 5/8 plug on the back of the MCV, had a trickle of oil and if I put my thumb on it, I could feel suction. We over filled it by 5 gallons of hy-tran thinking maybe the o-ring between the housing was leaking air, no help. We pressurized the fill hole with compressed air, no help.
I replaced the filter and cleaned the filter screen and housing, replaced the priority valve behind the battery, cleaned and rebuilt the MCV with all new springs, seals, o-rings and gaskets this last weekend. The rebuild kit came with diagrams for each spring and o-ring. I double checked the check valve and spring, to make sure they were installed correctly.
I pulled the 5/8 bleed plug again with no change in pressure. Finally with compressed air and the engine running it took prime and pressurized (and sprayed oil for about 10 seconds before I got the engine shut off). Put the plug back in and restarted the engine, still no brakes and very hard power steering. I did not drive it to check the TA. I cracked a line on the steering hand pump and spun the wheel to try and bleed the air out. I noticed the wheel turns easier to the left than to the right. It is almost impossible to turn to the right with the engine running.
I cracked the oil supply line at the brake pedals and have very low flow.
I cracked the line at each brake to try and bleed the air out and worked the pedal, I get air bubbles out, but never get fluid.
I loosened (not removed) the 5/8 plug again and get oil to trickle. I then loosened the plug on the top of the divider valve and get oil and air. Since I don?t have gauges, I do not know the pressure
I have a book coming (GSS-1343d) but it hasn?t arrived yet.
The pump sounds like it is caveating, but I don?t know where it is sucking air from. I am almost ready to take it to CIH to fix it??
This weekend I am planning on putting the old pump back on since it worked before I took it apart. The only thing I can think of is maybe the pump is sucking air around the shaft seal, or it is sucking air past one of the o-rings on the pump.
I have searched the forums and tried about everything that has been suggested so far. I am at a loss on where to look now, any suggestions would be greatly appreciated. Thank you.
