Ferguson Farmer
I recently bought a farmall 826 tractor. It starts hard, to the point where it will only start with starting fluid. When I use it I give it the smallest amount possible and it takes right off. It smokes and wet stacks. Could the injection pump timing be off? The previous owner removed it a few years ago and had it rebuilt by a reputable nearby shop. He claims that it is correctly timed but I’m not sure if it really is. I pull the fuel shutoff out until it just about touches the plunger in the pump to help it start, like stated in the manual and in other forums. It has two new 12v batteries wired in parallel. It’s a tight sounding and good running engine otherwise.
