Ferguson Farmer
I bought a farmall 826 a few months ago. The previous owner had the injection pump rebuilt a few years ago by a reputable repair shop. It is a pain to get started. It needs a shot of starting fluid but next to none will get it going. Then i need to nurse it with the overfuel cable for a while til it finally takes off and runs on its own. Plus it smokes and wet stacks. I understand that is the nature of the D-358. I checked my pump timing and it is set at 12 degrees before TDC. The book says it should be at 16 degrees before TDC. Could the incorrect timing be the culprit?
