farmall A 192 plow
I need help iam trying to do some plowing with the A and it will not go into the ground ( ground is very hard ). the shere is very worn. is this the problem? and where can I find a new or good used one? the number is ihc solid 0556. or can this one be rebilt? thanks. Bob
Steve Rea in Salem Ohio is now manufacturing. He bought a lot of Crescent Forge dies & patterns. He has a Face Book page called Ploworx or his ph. no. is 330-332-9386 or 330-277-76
Earl
(quoted from post at 12:33:39 10/17/15) I need help iam trying to do some plowing with the A and it will not go into the ground ( ground is very hard ). the shere is very worn. is this the problem? and where can I find a new or good used one? the number is ihc solid 0556. or can this one be rebilt? thanks. Bob
Any steel part could be built up with weld and re-shaped, but plow shears are not expensive. Check e-bay.
