Farmall A Carb
Kuebeck89
How do I know what Carburator is on my Farmall A? I need to rebuild it because of it leaking but don't know which kit to buy I'm sure it's the original carb on it.
Also, if it is a Zenith, there should be a round tag riveted to the body. The rivet will be in the middle of the round tag. The numbers on there will tell you which zenith you have. There were a couple of different variants. I truly can't remember if the rebuild kits were interchangeable for each one or not.
i couldnt read mine..have had good luck after it was open i could see what shape it was ,,and looked it up on the parts diagragm....dewy
