farmall a final drive
hotrodzz4
hello everyone, I have a super a that has a bad gear in the left hand final drive. it is the large gear at the bottom of the outer part of the axle. is this gear still available form IH or does anyone have one they would be willing to sell? also any idea as to why all forward gears work but reverse grinds? i have had the cover off and cant see any obvious problems. when i put the tractor in reverse by hand with the cover off i can turn the belt pulley and make the tractor move however with the engine running it just grinds in reverse. thanks for your help I can be reached at [email protected]
What happened to the bull gear? Did it chip a tooth or did something get loose and let it get out of line, is the drive gear good? I see em all the time on Ebay cheap however the shipping is getting high. As for reverse your shift fork may be bent and not pulling the gear far enough or the pin holding the fork to the shaft is sheared.
