Hi everyone,
Finally got the A running. Had some trouble at first with junk in the fuel tank. I took the tank off and cleaned it and it seems to run great now, picks up in 4th gear no problem. Only issue is it is hard to start. It has an H4 mag with no starter - hand crank only. I'll crank and crank with full choke, fuel dripping out of the carb and think for sure it is flooded. Then I take the plugs out and they aren't even wet - so I don't think it is getting any fuel up into the cylinder. Made sure manifold bolts and intake bolts are tight. Idle screw set 1 1/2 turns out. Checked spark just to make sure. Rechecked valve lash too.
Took the carb off and blew out the passages - didn't seem to help. Could the float setting affect it like this? It is just odd since it runs so well, but starts hard like this.
Thanks,
Noah
Thanks,
Noah
