farmall A lights
how are the lights operated? i see a switch with b,d,h,l,on it is this the light switch.also my left brake won,t hold linkage looks like it,s moving,is there a adjustment?.thanks
Look on the left side by the tranny and you will see the brake linkage and the clevis loosen the jam nut and screw the clevis to shorten the linkage. It will be rusty and probably hard to turn but thats what wd-40 or something like that is used for also your brake band could be bad or rusted out or running in oil because of leaky seal on the tranny.. If you get an owners manual the light wiring dia will be in it.
The half round cover is the bottom of the final drive gear . The brake band is inside the hole the brake rod goes into. You will need to pull the final drive to examine the brake band , Best done with an overhead crane or engine hoist
No the brake bamds are in the diff housings rite behind where the linkage goes thru. You need to remove the final on the right side to see the brake and remove the diff housing on the left at the tranny.
