Farmall A steering
I am working on a steering box for a Farmall A - it is the later style keyed taped shaft with nut and cotter key. I am using a tie rod puller to pull it. I have heated it and quenched it while hot with penetrating oil but I can not get it to release. what is the trick? Thanks for the help. Keith
Tighten the puller to its max and give it a few raps with a hammer. The shaft being tapered, it needs only to move a fraction of an inch to come loose.
Mine was very tight too. Finally got the arm off using a purposely built puller. If you need a description of that, send e-mail.
