Hello,I am back to working on the clubs Farmall A.It idles nice and runs good when under load,but when it is above 1/2 throttle without load it stumbles,unless some choke is applied.
I replaced points,condenser,cap,rotor,plugs and wires (magneto) checked rotor timing gears,but not governor end, rebuilt carb, but kit did not include main or idle jet,did have shafts.Every passage and jet is open.
Today while playing with it,I turned the idle mixture screw in to 3/8 turn out and it seems to run much better,I did not get a chance to run it under load.I thought the idle mixture screw would only affect idle not upper range.
