adamsih300u
Hello all,
I have a 1940 Farmall A I bought this summer and have been using for mowing my 3 acres with a 60" Woods mower. It's run well for me, though I discovered after buying a small crack in the block, which I sealed with JB Weld putty and has held well against the coolant.
I just finished an oil change before winter - new filter, dropped the pan to put on a new gasket. There was a slight gap in the oil pump cover gasket which I think has resulted in low oil pressure, but I'm having a hard time finding a replacement.
Anyways, after putting everything back together, I did some fairly heavy mowing and things seemed to be running well. I parked the tractor outside after mowing for a few hours. When I went to start it tonight, it fired right up and started vibrating terribly within a couple of moments. I switched off right away, and pushed into the garage. Tried cranking it with the ignition off, and it cranks and starts vibrating badly after a moment. I've posted a short video here if it helps: https://youtu.be/P0Pu71BHgNE
Thanks for any help and advice! I'm worried this could be a big issue...good thing winter's coming.
